質問
Lightroom is changing the lighting and colours on my raw photo and is adding noise
  • December 22, 2024
  • 返信数 1.
  • 1207 ビュー
Lightroom is changing the lighting and colours on my cr3 raw photo and is adding noise to it when I import it. The photo was taken on a canon m50 mark ii and this problem only started happening after the iOS 18.2 update. I am editing on an iPhone 16 pro max. I currently cannot edit any of my photos due to this. I have attached screenshots to show what is happening. My app is up to date, it is doing the same on the website as well as in photoshop. I'm not sure about any of the other apps. Please fix this asap.
返信数 1
Same on me If anyone know solution
Hi @anais_6453 and @hazar_?ahin8360! Are you having this issue when you export the images, or is it when you import them into the app?
If it's when you export them, could you go to Export As > More Options and share a screenshot showing the color space you're using? Also, please let me know which version of Lightroom you’re using. Thanks!
Alek
*(If you mention me with an @, like @Aleke, I’ll get a notification and can respond faster.)*
It is when I import them and then they're even worse when I export them. They're completely fine in my camera roll before hand. I'm using 10.1.1 and it's Lightroom photo editor on my iPhone.
Hey @anais_6453!
Could you head over to Settings > Photos on your iPhone? Look for a toggle called "View Full HDR." Please test if the images still look different with that toggle on or off.
Thanks a lot!
Alek
