質問
Is it still possible to download trial versions of CS6 products?
  • July 10, 2013
  • 返信数 2.
  • 1093 ビュー
I've spent most of the day trying to install Adobe After Effects CS6 trial version.  I finally managed to install the Creative Cloud version but I do NOT want Creative Cloud.
Are they two different versions?  Or if I purchase the CS6 version and fill in the serial number, will the CC download become CS6?
I looked under HELP to see if I needed to de-activate the Creative Cloud version before uninstalling it and saw an option to 'log out'.  I decided not to do anything before figuring out if they are one in the same or horses of different colors.
thanks,
Paz
    このトピックへの返信は締め切られました。
    返信数 2
    John T Smith
    pwillener
    You can download any CS6 trial from http://prodesigntools.com/adobe-cs6-direct-download-links.html - make sure you follow the Very Important Instructions before proceeding to the actual download.
    However, if you do not already have a CS6 serial number, I'm not sure if you can every activate it.
    P.S. this forum (called Forum Comments) is for the discussion of forum issues.  For product questions you should ask in the appropriate product forum.  For download and setup questions: http://forums.adobe.com/community/download_install_setup
