Adobe Premiere Pro - Need help with an audio pop in the middle of an audio clip
  • April 3, 2024
  • 0 replies
  • 270 views
So I'm adding a song to a video I'm working on and I noticed it has a pop in the middle of the song. I tried doing the traditional method of removing pops by using the default transition trick, and while it does get rid of the pop, you can tell that something got cut in the middle of the song which'll break the flow. (Even though one frame is cut you can tell there was a time cut with the instrumentation.) Is there any other method of getting rid of those pops? I'd redownload the song, but the song I'm using has been edited to be condensed and I don't want to reedit the song unless it's necessary. Thanks in advance!
