解決済み
Timeline disappears when I click on Effects
  • August 2, 2020
  • 返信数 3.
  • 6512 ビュー
Regarding Adobe Premier Pro v 14.0:
When I click on the Effects to add something like a video transition, the timeline dissapears, making it impossible for me to drag the feature.  This also happens when I click on the Colour tab, but I can adjust via effect controls (though not ideal for me). I read in a "solved" forum question that the person went to Geeksquad. They said there is a little icon inside the icon for the video in assembly that can be clicked to select "show hidden". I can't find this anywhere and it's impossible to continue editing with this problem. Here is the original thread I found, but it doesn't have clear enough information. https://community.adobe.com/t5/premiere-pro/timeline-disappears-when-i-click-on-effects/td-p/9935443?page=1 Can anybody help? Thank you!
このトピックへの返信は締め切られました。
解決に役立った回答 Peru Bob
Try resetting the preferences:
https://community.adobe.com/t5/premiere-pro/faq-how-to-reset-trash-preferences-in-premiere-pro/td-p/8236158?page=1
Reset a workspace
1. Do one of the following:
• Click the Workspace menu icon and select Reset to Saved Layout.
• Choose Window > Workspace > Reset to Saved Layout.
from here:
If that doesn't work, try Preferences > Audio Hardware and set Input to None.
If that doesn’t work, try updating or rolling back your graphics driver directly from the video card manufacturer’s site.
If that doesn't work, try creating a new project and import the old one into it.
Also, please help us help you:
https://community.adobe.com/t5/premiere-pro/faq-what-information-should-i-provide-when-asking-a-question-on-this-forum/td-p/3929027?page=1
返信数 3
Peru Bob
Peru BobCommunity Expert解決!
Reset a workspace
from here:
athbek
thank u so much for ur help!!! i was struggling for so long and ur solution worked right away ❤️
John T Smith
Do not count on Windows to be fully up to date when it comes to device drivers
Go to the vendor site to be sure you have an updated driver for your graphic adapter
•nVidia Driver Downloads http://www.nvidia.com/Download/index.aspx?lang=en-us
•ATI Driver https://www.amd.com/en/support
There are also intermittent reports that the newest driver is not always the best driver due to driver bugs or compatibility issues, so you MAY need to try an earlier driver version
John T Smith
Please post the exact name of the Adobe program you use so a Moderator may move this message to that forum
80twenty作成者
Thanks. I just edited it. This is my first time using the forum, I think.
