varxtis
解決済み
Pathfinder not working for what I need. Please help.
  • August 4, 2018
  • 返信数 6.
  • 15323 ビュー
Im having trouble getting some result that Im aiming for, and it has to do with the Pathfinder tool (I think). Can't really explain in text. so I made this video.
IIn short, I have 5 objects that are in a star pattern. I want to subtract a start shape from the center of the pattern shape, while retaining the outline of the fore most (center) star shape. So one object effecting/subtracting from five objects leaving a void in the center of the pattern shape AND retain the outline of the cent star shape.
    このトピックへの返信は締め切られました。
    解決に役立った回答 michelew83603738
    As I said, please try the Shape Builder tool, it will resolve your problem. It seems that you want to show us movies, but aren't really following our suggestions. For what you are trying to do, the Shape Builder tool will work and Jeff Witchel, ACI​ link will show you the best way to use it.
    返信数 6
    varxtis
    varxtis作成者
    Thank you all again. I a banging my head in confusion.Im pretty frustrated. Before using illustrator, before come to you for help, I had been learning Illustrator 101 via a youtube series by "Teach Me To Design" called "Adobe Illustrator Basics: Part...". In the very first video he discusses Shape Builder (directs to to time in video):
    Adobe Illustrator Basics: Part 01 - YouTube
    Ive used the Shape Builder tool numerous times already to create shapes. Again, this is prior to coming to you. Obviously I should have told you. This star shape is the first it hasn't worked on, and after numerous attempts, went the "Pathfinder" route, still with no success. I figured Shape Builder wasn't working because only the tips of the "Fins" are touching. Due to the emphasis you guys were putting on Shape Builder, I shook my, figured "what the heck", gave it another shot, and it works. But I don't get why. I didn't change anything. I have the same layers/objects selected as all previous attempts, same approach as all previous successful Shapes.
    Im embarrassed because I've clearly wasted your time, but at the same time, I don't know why it worked now and not earlier.
    I don't know what to say other than:
    Thank you for your time!
    Thank you for your patience!
    Thank you for your help!
    And Thank you!
    Jacob Bugge
    For my part you are welcome, varxtis.
    Apart from the fact that AI and PS are so different that in a way you may have to (partially) unlearn the latter to learn the former, depending upon your exact wishes/requirements there are usually more ways than one to perform a task, as this thread has demonstrated, in this case three/four sorts of ways outlined/suggested.
    And sometimes, the actual cause of the issue/hindrance will remain unknown.
    Anyroad, welcome to this helpful and friendly forum.
    varxtis
    varxtis作成者
    Monika Gause​ - Well, you made a great and straight forward suggestion. So since that line of my response was (@Monika Gause) that means I was replying to your suggestion. And since I said "I tried that" it means I tried your suggestion.
    Obviously I did something to confuse everyone. And I am very very sorry about that. I feel as though some of these suggestions are more complicated than the method needs to be.
    I REALLY do appreciate everyones time. So here is one more video. Sorry, a 3min video is better that 3hrs of trying to word an explanation properly, or do screenshot frames. An image is worth a thousand words, so a video is worth more. It provides context and goal if recorded right.
    Jacob Bugge
    varxtis,
    With the ways suggested in post #6 you can get to one group of objects (one of each) and have the artwork reversible/editable, or you can use Pathfinder operations (Divide and Unite with clearing up in between).
    And you can use the Shape Builder Tool, as suggested in posts #6&7.
    The destructive behaviour of PS is what makes it so simple to use (to get to an unscalable raster image).
    Ares Hovhannesyan
    May be I am wrong but I notice that not all layers are selected when you acting with pathfinder.
    Anyway i can suggest you to use Shape Builder Tool instead of Pathfinder Panel. Its easy to work and you can control all your steps.
    How to create shapes using the Shape Builder tool in Illustrator
    varxtis
    varxtis作成者
    First off, I thank you for your time and responses.
    Jacob Bugge​ - Thank you for the suggestion. I didn't want to make the explanation any more confusing than i was already making it in the video, but your method isn't the way I want to go about it. I have a reason that I need it the way Im trying to get it. In short, it'll be one object, not effected or dependent on any other layers or masks. I know there's a way to do it the way I'm wanting , because I accidentally did it, and can't repeat it. I think Monika and Michele are on the same train of thought as me.
    Monika Gause​ - I've tried that. Whenever I click the merge option, The stroked/outlined center star just disappears. I have tried arranging the center star to the front, and when the star disappeared, I tried arranging it to the back, with same results.
    michelew83603738​ - I have tried using all Pathfinder options with the center star arranged to the front and to the back. either way, I'm getting same results.
    Monika Gause
    varxtis  schrieb
    https://forums.adobe.com/people/Monika+Gause  - I've tried that.
    Tried what?
    Please show us (no video!) a screenshot of the layers panel (all objects need to be vsiible in there)
    Also: a screenshot in outline view.
    Then expand that stroke on the star
    Then select all and click on "Merge".
    And show a screenshot again. Preview as well as outline view.
    Monika Gause
    Outline the stroke on the star.
    Then select all the objects and click on the pathfinder button "Merge".
    Then delete the blue inner shape of the star.
    michelew83603738
    varxtis,
    The reason that this is happening is because of the way the minus front works. When you use minus front, it will subtract all shapes from the first or bottom shape in your layer panel that you have selected. You are assuming that it will only subtract the top most shape from all the other ones. It will subtract all shapes from the bottom shape that you have selected. That is why you are getting the shape left that you are - it is the first shape that you drew.
    What Monika said will work. Or you can select all of the shapes and use the Shape Builder tool holding down Alt/Opt to delete the pieces you don't want.
    Jacob Bugge
    varxtis,
    As I (mis)understand it, an easy and reversible way would be to:
    1) Copy the centre star behind itself (Ctrl/Cmd+C+B) and hide the original;
    2) Select the copy star and give it a white fill, then select everything and in the Transparency palette (flyout) click (Make) Opacity Mask with Clip unticked and Invert Mask ticked;
    3) Show the original again.
    This will show the original hollow centre star in front of the outer parts of the other objects. You can release the Opacity Mask and make any desired changes, then reapply.
