質問
Audio crackling sounds and audio issues after exporting with Premiere V 23.2
  • April 3, 2023
  • 返信数 1.
  • 253 ビュー
I also have audio problems with Premiere V 23.2. When I apply audio transitions or any audio effects on my audio clips I get terrible crackling sounds. BUT while Iam editing in the timeline everything sounds perfectly fine! I am exporting in differnt formats etc... but can't get rid of this issue. Especially with transistions. it's almost at the in and out point of the transition. But then I did volume fades manually. But then even had a situation where the edited music just cuts off. It gets quiter and then suddenly just drops. Only after I export. In my timeline it's perfectly fine. I really need help or get this bug fixed soon. I'm loosing so much time with testing and exporting differnt versions milloin times.
このトピックへの返信は締め切られました。
返信数 1
Hello @mariob89684730a,
Thanks for the message. It’s been a long time since you filed this bug, and I apologize for the lack of a response. Are you still having this issue? If so, the team will need more information from you to reproduce the bug. Is this audio from an OBS video stream? Can you provide the information required here? How do I write a bug report?
I'll move your post to the Discussions board while we await your information.
