Lumetri Color "Look" dropdown doesn't work properly on Macbooks with vertically stacked dual monitor
  • March 9, 2023
  • 372 views
When using a stacked dual monitor set up (one monitor above the other) on MacOS (2021 Macbook Pro M1 Max chip running Ventura), Premiere Pro's (23.2.0  Build 69) Lumetri Color panel seems to have issues with the dropdown for the Look field.
My primary monitor is the bottom monitor in this stacked setup, and both monitors are at a 2K resolution.
Within Premiere Pro, I'll go to the Creative tab in the Lumetri Color panel when Premiere Pro is opened on my bottom monitor and the dropdown is cut off:
Every time I want to use this drop-down field, I have to bring Premiere Pro to my top monitor, use the dropdown, then bring it back down (note this is the same window but on my top monitor):
I assume this is caused by some form of bug where it thinks it can expand to the space above (onto the top monitor), but it doesn't render that way on Macbooks.
Is there any known fix for this or a known bug I can upvote?
Kevin-Monahan
Hello @CircleHScuba,
Thanks for the message. It’s been a long time since you filed this bug, and I apologize for the lack of a response. Are you still having this issue? If so, the team will need more information from you to reproduce the bug. Can you provide the information required here? How do I write a bug report?
I'll move your post to the Discussions board while we await your information.
I'm having this same issue, with identical circumstances, and I can reproduce the bug in any vertical multiple monitor configuration. The menu works correctly when the Lumetri color window is placed on a monitor with no monitor set up above or below, but if the Lumetri color pane is moved onto a window that has another monitor arranged in any kind of vertical placement then it cuts off every dropdown menu when the box tries to either go up to fill the space above, or to go down and bleed down onto the monitor below.
I've had this since back about Pr2017. It is really annoying. I've brought it up here and other forums, and in person at NAB. Where devs have said something to the effect of ... huh, well, that's weird ... and gone on to something else.
It would be nice to get this fixed.
