Corner Pin problem in Premiere Pro
Community Beginner ,
Dec 13, 2023 Dec 13, 2023
I have a problem in premiere pro, with corner pin. After aplying, it makes some black lines.Edit Feedback.00_00_09_03.Still001.png
Bug Unresolved
2.3K
Community Expert , Mar 02, 2024 Mar 02, 2024
It has been fixed: 24.2.1. or use beta.
Votes
41 Comments
Jan 06, 2024 Jan 06, 2024
Not sure what you mean by interlaced (?). My source material is a video recorded by OBS capturing screen.
BTW, I checked out now Beta version and seems like the problem is solved there. I tried to figure out what's wrong for 2 hours and looks like it was a bug...
Votes
Interlacing means that each frame of video is made up of 2 fields... and in my opinion, is a legacy format that should be avoided at all costs, bwdik...  Some delivery specs require it and some shooting formats allow for it.  Happy to go in details, but since you're not dealing with it, probably not necessary.
Votes
If you mean these kind of lines its a know bug
revert to previous version or use the beta.
Votes
Contributor ,
Jan 19, 2024 Jan 19, 2024
Same problem for me. Hope they will fix this soon.
Votes
Issue has been fixed!
Votes
Fixed on official version?
Votes
Contributor ,
Jan 20, 2024 Jan 20, 2024
In which version? I'm up-to-date and I still have the problem.
I didn't try the beta (and I don't want to)
Votes
Like someone else I couldn't get this to work in 24.1. I downgraded to 24.0 and still having problems (lines in a corner pin that should easily be resolvable). But as someone suggested, putting an invert effect before and after the corner pin in the effects panel solves the issue.
Votes
Rendering under Media Encoder is showing same issue despite using the invert effect where in-place rendering looks OK now.
Votes
Downgraded to ME 24.0.3 and problem solved.
Votes
Adobe Employee ,
Jan 22, 2024 Jan 22, 2024
Sorry, @Alberto Bedin. I've been told it's been fixed in the beta version and the fix is not in included in the current version. Sorry about that.
Thanks,.
Votes
Feb 16, 2024 Feb 16, 2024
while i appreciate the hard work the team is doing on Ai... the corner pin tool has been broken for almost 2 months.
Votes
Feb 21, 2024 Feb 21, 2024
Loading this project up on my mac instead of PC fixed the issue.
Votes
Same problem. Please fix it asap!
Votes
Votes
Mar 15, 2024 Mar 15, 2024
use the Basic 3D effect as well for an easy work around
Votes
