Corner Pin problem in Premiere Pro
Community Beginner ,
Dec 13, 2023 Dec 13, 2023
I have a problem in premiere pro, with corner pin. After aplying, it makes some black lines.Edit Feedback.00_00_09_03.Still001.png
Bug Unresolved
2.1K
Community Expert , Mar 02, 2024 Mar 02, 2024
It has been fixed: 24.2.1. or use beta.
Votes
41 Comments
Explorer ,
Dec 10, 2023 Dec 10, 2023
im getting black lines in my images when using corner pin
it appears in the program monitor and in exports. it changes like moiré when i adjust it..
it disapears when corner pin is disabled
anyone know if this is normal or a bug? thx
windows 11
13th Gen Intel(R) Core(TM) i7-13700F
32 gb
RTX 4060
premiere 24.1.0 build 85
Votes
I have seen this with corner pin
Votes
Explorer ,
Oh oups i realize it's actually corner pin that the problem! I'll edit the post with the info and my effect stack
Votes
Dec 11, 2023 Dec 11, 2023
I have the excact same issue.. any progress?
Votes
Votes
Thanks - but I'm not using any transition. All I've done is to place a scrolling page (screen recording) into a monitor.. I've done this plenty of times, and never had this issue. I've tried multiple screen recordings in different resolutions, and they all get stripes. I've even tried other stock videos with green screen monitors, but all with same result..  ¯\_(ツ)_/¯
Votes
Explorer ,
Unfortunately your link doesn't offer any solution..
so no progress, I don't use transition either.. it looks like it's simply a corner pin bug
Votes
Corner Pin as a gpu acc effect has been under development for a long time now.
Not expecting a fix any time soon.
Votes
Thanks. I updated to Beta - and now it works perfect again. No lines 👌👌
Votes
Explorer ,
reinstalling didnt fix it,  but beta did..
Votes
Dec 12, 2023 Dec 12, 2023
Votes
Came here to say I'm having the exact same issue. I noticed it on a project that I had been working on when all of the clips I had corner pinned had strange vertical lines. Messing with the dimensions more revealed the moire effect. I rolled back Premiere from 24.1 to 24.0.3 and it fixed the issue. Here's my documentation of the issue (yes I was a dummy and posted it to the wrong subreddit): https://www.reddit.com/r/AfterEffects/s/a5wMT4ZUv0
Votes
<"moved from cc desktop bugs">
Votes
Known bug. No solution yet.
Votes
So it is not a problem with my graphics card.
Votes
Participant ,
Dec 14, 2023 Dec 14, 2023
Yes, I had the same. No issue in 24.0 only showed up for me in 24.1
Hey, I just did some playing around and found a work-a-round in v24.1 if one prefers not to go back a version or to beta.
I put the invert effect before and after the corner pin effect, lines are gone. Not elegant, yet my day can progress... 🙂
Votes
Same here, still no cure for this
Votes
Dec 15, 2023 Dec 15, 2023
Roll back a version or use the beta.
Votes
Yes, it works, I upgrade to Beta version & back to normal
Votes
Dec 17, 2023 Dec 17, 2023
Can confirm that a downgrade vom 24.1 to 24.0.3 fixes the problem with the corner pin effect. (Win11, RX6600, AMD processor)
Votes
Jan 02, 2024 Jan 02, 2024
Apparently when I have a clip with the Corner Pin Effect applied I get striation patterns appearing on my image. I never had this problem with previous versios of Premiere. Is there a way to circumvent this? I hope this gets fixed soon.
Votes
Jan 03, 2024 Jan 03, 2024
@tomSDN14713793
I've moved your post to the Premiere Pro forum for you.
Jane
Votes
Known bug: revert to previous version or use the beta.
Votes
Jan 06, 2024 Jan 06, 2024
Hey,
I have a problem with Premiere Pro showing lines-artifacts when using Corner Pin in a way that program
Task:
  • General idea is to a add video to a mockup of smartphone.
  • It requires cropping of a video which is recorded in 1920x1080;
  • It requires placing cropped video on a mockup;
My way of dealing with it:
  1. Adding cropping effect and cropping it + creating mask on opacity to round the corners.
    2. Using rotation, position and scale to roughly place video in the right spot.
  2. Creating nest (*)
    3.  Adding corner pin effect and dragging points so it would fit the smartphone perfectly.
    (*) nest is applied to get corners of pin effect closer to the area that actually must be visible
Problem  - although it is the easiest way to to this it creates visual artifacts (lines) when perspective is pushed beyond what program thinks is acceptable, even though the perspective looks natural.
I had no such problems with other mockups (usually, artifacts appeared only when perspective was weird) but this one seems problematic for PP.
My solution (terrible one) - avoid corner pin and using Basic 3D & Transform. Way less accurate and way more time consuming.
I guess, I'm doing something wrong but it must be something obvious since I see no topics related to this issue.
I'm attaching video with visible artifacts + file of PP (with video clip and mockup) where one clip is created using corner pin and second one using transform and basic 3d.
Votes
just a quick thought.  Are you using any source material that's interlaced?
Votes
